diy prom questions???
Old Aug 6, 2001 | 06:35 PM
brettd's Avatar
I have an 86 t/a and i am swapping a 350 into it and i am keeping the stock tpi i want to know what is the part number for the prom that would suit this swap until i can finish getting all of my prom burning material together?? I also have another question how can i burn my proms i have an 86 and i hear people talking about the memcal can someone shed some light here at first i thought i could just yank the chip erase it prog and slap it back in the car but someone was talking about the memcal on 86 model tpi
Thanx in advance = )
Brett
Brettd@broadcast.net
Old Aug 6, 2001 | 06:39 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Look at running the ARAP.BIN (89 MAF). All you have to do is disable the 9th Injector.
I don't know what the actual Memcal Part Number for the ARAP Bin is, but someone recently got one and maybe they can share it with you.
Alternatively, do a "search" on the DIY PROM Board for "ARAP" and you should be able for to find the post (plus a lot of other info on the ARAP BIN) which you will find useful.
Old Aug 6, 2001 | 06:55 PM
brettd's Avatar
thanx glenn
Old Aug 6, 2001 | 07:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
</font>
The actual part no for the ARAP was 16134193, but it's been superceeded, I know of at least 3 updates to it. Depending on your parts guys thou, this might be the simpliest answer, since all he has to do is follow the look up sheet.
You actually want the latest part number per your application in case there were any netres or ESC updates.
Old Aug 6, 2001 | 07:32 PM
brettd's Avatar
but i should look at running a chip out of an 89 until i get my prom burning stuff together??
Old Aug 8, 2001 | 09:41 AM
Car: Death Mobile
Engine: 666 c.i.
You would still have to have the ARAP BIN modified, since ARAP supports VATS and your car does not have VATS.
Also, while I have played with the ARAP BIN, I have not seen the actual programming that is on the Memcal. If it (the Memcal) is the same as the ARAP BIN, you will need to adjust the Fan Switch for Normal Operation.
Old Aug 8, 2001 | 01:53 PM
brettd's Avatar
Thanx for the response guys. I looked up the arap.bin and found out exactly what it is it is a performance chipset that was used in the cars gm would give to magazines for performance tests = ). Until I get my prom burning equipment will i even be able to start up the 350 with my 86 305tpi chip still in it? Also what tuner should i use and what will it cost i know people say tunercat is good but is there another that is better ?? and if i do use tunercat someone said i need some configuration files to read the 89 arap.bin file anyone know where i can find that??
Old Aug 8, 2001 | 02:53 PM
leirch's Avatar
You'll be able to run the car just fine. Not optimally. It should let you break the car in.
Brendan
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
