Temp sensor differences?
Old Sep 17, 2006 | 01:23 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
I was at the junkyard and snagged a couple temp sensors from different vehicles because they were easy to get too...
Are there any differences in the voltage signal from model to model? I only got the ones with the yellow and black wires, but they were from an 90 Lumina and an 87 Bonnevile.
At the time I was thinking that 180 degress is 180 degrees no matter what, but I failed to consider that one might send a different voltage for that temperature (or any given temp).
I also found one in my parts pile and it had a smaller prong that goes into the coolant. It also had a different 2 wire connector, but if I changed the connector would that one work as well?
Old Sep 17, 2006 | 10:05 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally Posted by AtomicTruck
Are there any differences in the voltage signal from model to model? ?
Not that I've seen, or noticed, what does change is response times. An exposed element is faster reacting then say a coolant sensor, where the sensor is hiden behind the brass case.
Bstrang6
Sep 8, 2015 04:29 PM
bamaboy0323
Sep 3, 2015 06:07 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
