Sockets and such
Old Aug 14, 2001 | 05:05 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
Sockets and such
FYI, I have soldered a machined socket onto my MemCal in place of the original EPROM. It accepts chips with a moderate press fit. To swap out chips, I pull the whole MemCal, remove the lid (or hat or cover or whatever), then swap out the chips, replace the lid, and then reinstall the MemCal.
Having done this about three dozen times, now, I am beginning to worry about wear and tear on the pins in the ECM and the sockets on the MemCal.
Should I leave the MemCal installed (without it's lid) and just remove the chip from it from now on? What's the most common "system" used for swapping chips? I don't think a ZIF socket will fit under the MemCal's lid, will it?
'87 IROC 5.7l TPI - original owner!
Old Aug 14, 2001 | 09:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by P J Moran:
</font>
I got about 400 chip changes with a 747, before the socket gave out.
I've never found a decent ZIF to fit under any lid. There are some that use a slide bar, instead of a lift bar, but so far they all have seemed too cheap to even use.
Might just build a ZIF memcal for when experimenting, and then use the one you already have when doing long term testing with a chip.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
ramicio
Sep 28, 2015 01:18 PM
roysatikas
Sep 22, 2015 08:15 PM
