Blank Chips
Old Aug 15, 2001 | 08:43 PM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
Blank Chips
I have ordered a complete chip burning setup from BM Computer Source for my '87 GN. I have also bought a copy of tunercat and the tdf file I need to read and modify my prom on my '87 Formula 350. OK, here's the question: What kind of blanks do I need to have as spares and swapouts?
Someone had said a 27C128. I have two that are labeled - AM27C128
-150DC
9603APA
12.75V PGM
Will that work?
dgreene
'87 Firebird Formula 350 TPI, Ported Plenum, Adj. Fuel reg, gutted cat, catback exhaust, air foil, K&N air filter, chip,170 thermostat,Borg Warner Posi 9 Bolt w/ 3.23 gears....soon to be making custom chips for this and my 87' GN
Old Aug 16, 2001 | 12:27 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by dgreene:
-150DC
9603APA
12.75V PGM
Will that work?
</font>
The 27128s are fine and wiil work on the TPI. THe GN uses the 2732 series of proms.
The 87 uses a 165 ecm which uses a memcal that you'll need to modify, the GN uses the 148 ecm and uses prom holders.
At the Gnttype site they show the prom holders, and how to load and unload them.
Old Aug 16, 2001 | 12:38 AM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
Thanks Grumpy. I already have three chips coming with my setup for the GN. I also have my original memcal out of my formula modified with a ZIF socket. THe strangest thing is where I found those 27128s that I have. They were in some old ISA Adaptec SCSI cards that I had put in a box 3 or 4 years ago. The model number for those is AVA-1515. I noticed the bootrom on them was 28 pin so I pulled the sticker back, and saw the numbers and thought "man is that luck or what?".
dgreene
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
