EBL-IAC Control 84 Corvette
Old Sep 18, 2006 | 08:50 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
I have been working on IAC control with my 84 Corvette and I am stumped. After the motor is warmed up no matter what I do the idle will always shoot to 1000 rpm and decay. I also have a issue where on cold start the same thing happens. Start - idle shoots up to 1000 rpm and then it will decay real fast instead of a smooth idle down. What items should I be looking at?
Old Sep 18, 2006 | 10:34 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Have you looked at the IAC Idle Down Rate table?
Old Sep 18, 2006 | 11:01 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
Yes. The interesting thing is hot or cold it will idle down fast at about the same time period. When cold it will initially start at 1400 rpm and then idle down at the same rate. It is odd... I figure it has to be something stupid.
Old Sep 19, 2006 | 06:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On a warm idle set the throttle blades to give between 5 & 10 IAC steps.
If that doesn't fix it make a data log of a couple of start ups. And email it to me. I'll take a look at what it is doing.
RBob.
Old Sep 20, 2006 | 08:39 AM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
RBob - Email on the way.
Old Sep 24, 2006 | 01:13 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
isnt the 5 too 10 step, of IAC, a little high for a warm idle, ??? aim for the zero ??
Old Sep 24, 2006 | 05:09 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No.
Not always, on some codes that seems to work best, but not all.
PurelyPMD
May 5, 2016 04:57 PM
Drone358
Dec 10, 2015 08:16 PM
Doobie52
Sep 11, 2015 06:19 PM
scottmoyer
Sep 7, 2015 07:06 PM
dbrochard
Sep 7, 2015 09:41 AM
