Need help from PROM pro's...
Old Sep 14, 2001 | 12:26 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I have read all the previous posts and am still wondering what the BLM does? I know its the Block Learn thing, but how does that help me when watching thru a scanner.
Also, I have bumped up my MAP and TPS Accelpump in uSec array. Not by much tho. Mostly I changed things like idle speed and IAC / temp. ***Generally***, what will the effects of the Accelpump changes be, if any without modifying the spark advance table?
There is a value for "Max RPM spark slope". Is this where the computer backs off timing at a certain RPM, and then decays and couple degrees per RPM? If I have an MSD 6AL, which should be good for like 10000 rpm, should I set the decay rate down? I'll post the signature so if you need to know, there's all my mods.
TIA
'92 Astro 350 TBI Edelbrock intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's
Old Sep 17, 2001 | 12:22 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Hmm, I guess no one here has ever heard of this, funny, I thought this was a DIY PROM help board.
my mistake
Old Sep 17, 2001 | 07:39 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The BLM question is very basic. There are many posts that already answer this question. Not sure on the spark question since I have never worked with a TBI.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Sep 17, 2001 | 09:35 AM
davidjon_99's Avatar
I'm not much help, but watch your BLM and you want to be as close to 128 as possible. I just got my scanner running and my BLM seems to be running below 128 (running rich I think) with the stock programming.
Your question about the accelpump stuff is interesting because I have the same questions.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
dusterbd
Sep 29, 2015 08:40 AM
