4 diffrent chips for a 86 5-speed which should I use for the swap (please help)
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I swapped in a 5 speed for my auto a few years ago, I finaly found a computer from the same exact car as mine execpt this one was a orignal 5 speed car. The tranny I put in the car is from a 88 iroc not a 86 but that should not matter. The chip in my car was a ffa, and the new one is a anw. The computers are the same, this chip matches up to a m39 5 speed car, there is one other chip for a m39 car and 2 for a mc4 tranny. What is the diffrences? CAn my car go in to closed loop in with the auto car? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: Death Mobile
Engine: 666 c.i.
You should use the "standard transmission" eprom with a "standard car". Standards tend to have slightly different spark tables.
I don't believe using an Auto eprom will trigger an SES code as there is no "feedback" when it attempts to "lock" the TCC.
Car: 86 Z28
I want to use the standard chip but my Q is which should I use what is the diffrence? they list 4 for the same computer and for the same year.
I'd say to just give it a try. The only difference in the chips may be rear end gear ratio? Maybe california chip?
You can always put the auto chip back in.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
I also swapped a 88 t-5 for the stock 700 r4 in my 86 IROC.I used the auto chip for over a year. It ran ok but it never did seem right. Now that I have been burning my own proms it runs 1000% better.
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
My own prom (finally)
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
NBrehm
Aug 25, 2015 11:49 PM
