symptoms of bad TPS sensor
Old Oct 5, 2006 | 02:03 PM
Ronny's Avatar
with "whats up EBL" i see my TPS % increase as i depress the gas ing on-engine off. it his a definitive test that my sensor is properly functioning? or is a voltmeter test validating smoothness a better test?
Old Oct 5, 2006 | 03:00 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
check it with voltmeter,i believe in the haynes manual it says what the voltage should be at idle
Old Oct 5, 2006 | 04:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Problems with the TPS sensor usually show up as dead spots in acceleration. This is from the lack of AE. Or, DE being activated as the signal drops (like the gas pedal was lifted).
Can use the WUD to check it as you have done. Just move the gas pedal slowly and watch the bar graph. It should react smoothly to pedal changes. A worn out TPS is usually at and off idle. This is where the most usage occurs.
RBob.
soarestransam
Aug 24, 2015 08:15 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
