Still having problems with 600Mhz Laptop...
Old Oct 3, 2001 | 06:57 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Well, as of my last post, I couldn't get Moate's software to load with the computer in windows...so I logged in in safe mode...that worked like a charm...or so I thought. After a data log run, there are 15+ second blank spots where it recorded nothing. YOu can tell it is locking up or hanging by looking at the screen cuz the values cease to update for a while...then start updating again...I made a prompt so I could restart WinME in Dos mode and it won't even connect again in dos mode...
My question is...
Is anyone else out there successfully running Moate's software with WinME? My next step is to install the WinME patches I found on MS's website...then after that my idea is to format the C:\ drive and piece through installing Win98...
I will try Craig's latest rev first though...
Thanks,
GregF
87 IROC
[This message has been edited by gsf-87IROC (edited October 03, 2001).]
Old Oct 4, 2001 | 10:34 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have that same problem with Win98SE on my 75MHz Pentium Toshiba. I am pretty sure that others have the same trouble with multiple OSes. Craig is aware of these issues and I am pretty sure he is working on it..........
Good Luck
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 5, 2001 | 06:55 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
<font face="Verdana, Arial" size="2">Originally posted by Matt87GTA:
Good Luck
</font>
Thanks for the help...maybe I won't be so quick to format the C:/ drive then...maybe it also isn't the speed of my laptop then either...
GregF
87 IROC
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
