main spark advance
Old Oct 5, 2001 | 08:43 AM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
main spark advance
The stock values for my 89 are as follows: This may not work trying to paste.
20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0
20.0 20.0 29.9 29.9 29.9 27.1 22.9 20.0 17.9 17.9 17.9 17.9
20.0 29.9 40.1 38.0 35.9 34.1 29.9 26.0 22.1 20.0 17.9 17.9
29.9 34.8 40.1 40.1 40.1 35.9 33.0 28.1 26.0 22.1 17.9 17.9
41.1 41.1 41.1 41.1 40.1 36.9 34.1 30.9 29.9 23.9 20.0 17.9
43.9 43.9 43.9 43.9 41.8 38.0 35.9 32.0 28.8 27.1 22.1 17.9
46.1 46.1 46.1 46.1 46.1 43.9 38.0 35.9 34.1 27.1 22.9 20.0
48.2 48.2 48.2 47.1 46.1 45.0 43.9 36.9 34.1 27.1 23.9 22.1
48.2 48.2 48.2 47.1 47.1 46.1 43.9 39.0 33.0 27.1 23.9 22.1
48.2 48.2 48.2 47.1 47.1 46.1 43.9 41.1 32.0 28.1 23.9 22.1
48.2 48.2 48.2 47.1 47.1 43.9 43.9 34.1 29.9 26.0 22.9 20.0
47.1 47.1 47.1 46.1 41.8 41.1 38.0 30.9 26.0 22.9 22.9 22.9
47.1 47.1 47.1 45.0 40.1 39.0 38.0 30.9 26.0 23.9 23.9 23.9
47.1 47.1 47.1 45.0 40.1 39.0 38.0 30.9 27.1 27.1 27.1 27.1
47.1 47.1 47.1 45.0 40.1 39.0 38.0 33.0 28.8 28.8 28.8 28.8
47.1 47.1 47.1 45.0 40.1 39.0 38.0 35.2 29.9 29.9 29.9 29.9
These are not perfectly aligned, but the 3 below each line just continue after the prior line...hope you follow and the load / rpm follow the same format.
These turned out much better that I expected. Perhaps someone else could post their on a more aggressive timing curve to give me an idea what to do. I'll keep my fingers crossed.
[Modified by ski_dwn_it, 2:11 PM 10/4/2001]
White 89 Corvette....
Open Air box
Relocated MAT
Air foil
160 Stat
Lower Coolant Sensor
13.6 1/4 mile Total Stock
Old Oct 6, 2001 | 12:44 AM
fast_broker's Avatar
How did you get those numbers? reading the PROM? That curve doesn't look all that bad to me.
You'll need some diag software with a capture mode to get much better without hurting the engine.
db057
Sep 4, 2015 07:57 AM
Justin69
Aug 31, 2015 11:31 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
