Double check on final tuning...
Old Oct 7, 2001 | 11:52 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I want the BLM locked at 128 to keep the INT from going to far off and reseting?
An INT reading of 115 means too rich and the computer is pulling fuel out? and vice versa?
Some knock is normal, so if I get 1 or 2 counts here and there I should leave it alone right?
'92 Astro 350 TBI Edelbrock intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Oct 9, 2001 | 08:40 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You only want to lock in the BLM for fine-tuning the VE table, and only once you have your BLMs in the 126-130 range. Otherwise, you don't want/need the BLM locked.
Yes, 115 is too rich and the computer is injecting less fuel to bring the A/F ratio back to stoich. Yep, higher than 128 is lean, etc.
1-2 knock counts is OK, and can almost be expected when the tranny shifts.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 9, 2001 | 09:00 AM
fast_broker's Avatar
I don't bother with the INT at all if I have the BLM's at near 128. Tried locking BLM once or twice and didn't see any noticeable change for all the extra work. The main benefits will be from getting BLM as close to 128 as you can, iwthin say 2 on either side of stoich, which is about 1.5%, or close enough for me. I'll let the ECU do the rest.
EDIT: IMO, I don't like any knock counts (tranny change ok, obviously) because the ECU retards the spark so much. Unless you have changed the retard parameters to smaller values, then "never mind".
[This message has been edited by fast_broker (edited October 09, 2001).]
Old Oct 9, 2001 | 08:39 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
alright. Now I'm set, thanks
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
fbirdroller
Sep 2, 2015 10:27 PM
