ENRICHING FUEL
Old Oct 15, 2001 | 04:56 PM
programineproms's Avatar
ENRICHING FUEL
ok i need to enrich the fuel air ratio by 10%. i have tuner cat, ho do i go about doing this?
Old Oct 15, 2001 | 05:15 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Thats a broad question. Where does the fuel table need to be enriched? If you have a speed density car, then you want to increase specific cells on you VE table, or Fuel Table #1. But you didn't say where you need more fuel. Where you do this is going to be some combo of RPM and KPa.
'92 Astro, GM crate 350, Performer TBI intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Oct 15, 2001 | 06:19 PM
Bobalos's Avatar
Trick question. the trick answer is change the injector size by 10%.
BW
Old Oct 15, 2001 | 06:34 PM
ok ill try to make it less broad
Old Oct 15, 2001 | 06:36 PM
fast_broker's Avatar
Or increase Fuel Pressure by (1.10^2) percent, or 21% for 10% increase in flow rate.
Old Oct 15, 2001 | 06:37 PM
how do change the injector size?
Old Oct 15, 2001 | 10:18 PM
Bobalos's Avatar
I use GME Pro & it is called "injector flow rate for Double fire". it is expressed in lb/hr.
Old Oct 16, 2001 | 01:48 PM
now i have found where to change it at but its at .5 how do i raise it by 10%?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mike_c
Aug 27, 2015 04:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
