Ostrich!
Old Oct 13, 2006 | 01:32 PM
86z28iroc-z's Avatar
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
Ostrich!
Hey, i was just wondering if when i purchased this emulator, would it come with everything that I needed to get going? Or would I have to purchase some other compenents seperately.
Also, does it allow me to datalog??
Thanks!
Old Oct 13, 2006 | 02:40 PM
Sil's Avatar
Sil
Car: 1993 Pontiac Grand prix
Engine: 2.8/3100
Transmission: 4T60-E
the ostrich will allow you to use compatible tuning software (ie.. tunerpro rt, c.a.t.s ect..)to edit the the binary which would now be on the eeprom on the ostrich, the ostrich then emulates the chip in realtime to the ecu.
datalogging will need to be done with a seperate aldl device
ps: if your going to buy the ostrich there is a group buy going on, so you may get it cheaper if purchased before oct31
V6Z24.com :: View topic - Eprom emulator group buy... Updated 10/8
Make sure to put "V6Z24.com group buy" in the comments section of the order form so they know you are part of the GB
Old Oct 13, 2006 | 04:23 PM
southernspeed's Avatar
Car: '91 K5 Blazer, '05 Ram Daytona QC
Depending on what ECU you're using you'll need to adapt it to accept the Ostrich. All needed is available from Craig Moates.
Old Oct 13, 2006 | 04:32 PM
Sil's Avatar
Sil
Engine: 2.8/3100
yup, forgot to mention, you could use an adapter such as
G1 Memory Adapter: TPI ETC.. [G1] - $35.00 : Moates.Net
or
- They're IN!! Memcal adapters for all!
which is cheaper than moates :P
you can pm ryan.hess and ask about an aldl cable too
Old Oct 23, 2006 | 07:16 AM
thefightback's Avatar
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
or you can just cut the guts (PROM) out of your existing memcal. then just plug the ostrich into that.
355tpipickup
Aug 19, 2015 10:02 PM
jeeps2creep
17
Feb 4, 2007 10:30 PM
Grumpy
Oct 19, 2005 12:09 AM
anesthes
Sep 21, 2005 09:36 AM
smokefan
Apr 29, 2005 11:58 AM
