Adjusted VE for BLM and nothing happend...
Old Oct 23, 2001 | 03:39 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
well, actually the BLM stayed the same and INT went up. Then the SES light came on after I was off the highway.
Am I missing something here? The BLM stays at 117 on the highway and the INT went from 128 to 135. Something is fishy...
'92 Astro, GM crate 350, Performer TBI intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Oct 23, 2001 | 04:45 PM
JPrevost's Avatar
Car: 91 Red Sled
How fast is your ecm data stream? I was doing the same thing and I can't watch the INT, it's all over the place. I just go by the BLM. Maybe if you bump fuel pressure and do nothing else, then do the same test run, see what the BLM is at. If it's going down then you know it's working. Go the other way with the fuel pressure and it should bo up.
, Jon (350 TBI!)
91 Red My website
Old Oct 23, 2001 | 05:42 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
It's a 160 baud ECM.
Maybe I should try the V6 FPR spring? Its only a couple ticks lower than the 350 spring. It can't be much different, since I'm only working with 10-15 psi I think.
[This message has been edited by V8Astro Captain (edited October 23, 2001).]
Old Oct 23, 2001 | 06:05 PM
fast_broker's Avatar
Did you burn a new PROM with the adjusted value as I explained? In the VE tables that you are using while on the highway??? ie, RPM and MAP areas??? If you changes it, your BLM will change. Simple as that. If you change the wrong VE cell, you will see NO change in BLM as the operating cell during ighway travel is not the one you changed. Does that make sense? ie, how did you change VE to fix BLM? exactly???
Are you using TUNERCAT? If so, cut-and-paste the before and after Main Fuel Table here. OR EMAIL THEM to me, if you like. ie, one for each PROM. And tell me exactly where you run on the highway, RPM and MAP wise and point out the changes you made. I can help.
[This message has been edited by fast_broker (edited October 23, 2001).]
InfernalVortex
Apr 20, 2021 11:31 AM
Mark_ZZ3
May 24, 2018 01:02 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
