Which code to run?
Old Oct 24, 2001 | 04:14 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Which code to run?
I'm not sure i have ever seen this addressed here. I have a 92 Z28 vert w/ LB9 and am just wondering if there is any significant difference code wise between the 305 and 350 PROMs and which may be better. I'd copy the VE/PE and spark related data from my 305 into the 350 bin if i was going to change.
I'll prolly try it either way, i'm just wondering if anybody else has already done so.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.7 @ 93.6
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 24, 2001 | 09:26 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
</font>
Always better to start with a MEMCAL for the right application. Remember the knock sensor stuff is on the memcal. Might run into problems.
Old Oct 27, 2001 | 11:42 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There's very little difference in the fuel and spark tables between a 305 and a 350, anyway. A 350 bin would probably be closer to what you want tho, so you'd have to change less things. AUJP is a 92 350 L98.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
squiggy2
Aug 9, 2015 09:30 PM
