What is the best and easiest hardware to use for burning chips?
Old Oct 28, 2001 | 09:07 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I am looking into burning my own chips. I need to know what is the easiest and the best hardware to use ( programmer, eraser).
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
LT1 intake soon...if I can find one!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!!
Flowmaster exhaust
LT1 Injectors
LT1 intake also if I can find one!!
Old Oct 29, 2001 | 01:23 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well, I, and a lot of other guys around here, are using EEPROMs (Electronically Erasable Programmable Read Only Memory) with the Pocket Programmer from Intronics.... This is the best way to go, IMHO, as you don't need an eraser at all. The chips can be erased and programmed all at one time on the Pocket Programmer itself in a matter of seconds. Plus the flash PROMs last virtually forever, while the UV light erased chips will wear out after a finite number of erases/reprograms.
Go here for info on the Pocket Programmer:
Xtronics Pocket Programmer
I got my EEPROMs (AT29C256s) from Insight Electronics. The only down side to going with them is that they have a $50 minimum order and you will have to buy about 12 chips to reach the minimum amount.... Which reminds me that I still have about 5 AT29C256 EEPROMs from my original order that I am not using and am willing to sell... email me if interrested.
Hope that helps
Good Luck
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 29, 2001 | 07:49 PM
AaronIROCZ's Avatar
How are you burning your chips,(getting it to fit wo the programmer) as in which adapter are you using or which one is the easiest. And also which editor program are you using?
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
had engine fire
SHE NOW RUNS!!!!
Flowmaster exhaust
LT1 Injectors
Old Oct 29, 2001 | 08:32 PM
Matt87GTA's Avatar
I bought ZIF sockets and was going to use them and pull the chip itself off the Memcal every time I wanted to burn a new version. But I decided that it is really a lot easier to use the adapter that has the legs on it that will go into the Pocket Programmer itself and accept the Memcal directly. Then I just soldered in my AT29C256 EEPROMs onto the Memcals that I use and I don't have to do any handling of the EEPROMs directly. This setup has got to be the easiest way out there to erase and reburn the EEPROMs.
So now I have a few ZIF sockets that are just collecting dust but I wanted to buy everything that I would need to do it either way when I bought the ZIFs and the adapters so I wouldn't have to pay the shipping again if one method worked better than the other.
The ZIF socket setup makes much more sense for a regualer UV light erased EPROM setup as you can take the EPROM off the memcal and do the deed, and then slap the EPROM back into the ZIF on the Memcal......
I was using Winbin in the beginning, but I had *LOTS* of problems with it. So I bought TunerCat and I love it. It is very easy to use (much easier to work with than Winbin) and has proven itself to be worth the money, IMO...
1987 GTA L98 MD8
My GTA
Old Oct 31, 2001 | 07:58 PM
Matt87GTA's Avatar
Update: The 5 spare AT29C256 EEPROMs that I had up for sale have been sold. So go buy your own!! J/K .... (I got them from www.JDR.com if you need them....)
Thanks, all.....
1987 GTA L98 MD8
My GTA
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
88CamZ
Oct 8, 2015 10:29 AM
meeklay812
Oct 1, 2015 03:46 PM
Deemax
Sep 12, 2015 06:53 PM
