ZZ3/4 eprom in the LB9?
Old Nov 14, 2001 | 11:08 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I will be putting the ZZ3 cam in. I will be porting stock heads and installing w/bigger valves. Porting intake too.
My question is:
- could I just buy the Eprom from the ZZ3/4 engine and put it in?
If i replace the knock sensor and spark module with the 350 one would it work better than my stock 305 TPI EPROM?
What do you guys think?
89Iroc, 305 TPI, WC T5, 3.08 Posi, Headers, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, AFPR, All free mods,
Old Nov 15, 2001 | 07:34 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The chip for the ZZ3/4 engine is for a computer-controlled Q-Jet, not TPI, so it won't work at all. Your best bet is to start with the ARAP chip (or just the bin) and burn your own. Installing the 350 knock sensor and module is a good idea.
Greg Westphal
'87 IROC 355TPI/A4
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
gta90
Sep 15, 2015 04:00 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
the_nikfive
Aug 11, 2015 02:46 AM
