WBO2 LM-1 to Autoprom to TP datalog
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
I typed up some directions on how to set everything up to datalog into TP from LM-1 (or LC-1) through an Autoprom. You can find it at Moates.net in the documentation section.
I used this method because I'm not going to leave the WBO2 in the vehicle. Hope it helps.
