SES light..
Old Nov 23, 2006 | 09:05 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
SES light..
Hello all,
Old Nov 23, 2006 | 09:41 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Yes the SES will come on if you made a change and did not make the checksum update. You will be in limp mode.
The KR in AUJP can be up to 20* (not in PE) at 100 Kpa
($8220-$8228)
0* KR below 50 Kpa
50 Kpa = 4.9*
60 Kpa = 10*
70-100 Kpa = 20*
($8218-821F)
13-15* when in PE mode (this one is RPM based).
To disable it you can:
raise the min KR engin temp to 255 at 820C
Not really advisable to totally "lock it out", better to reduce the amount of KR attack rate at ($820E-$8212) and in the above tables and add more to the Knock recover ($8213) so it comes back once the knock is gone.
Adding allot to the recovery table is a good option if you are having knock but want to leave the stock tables alone.
eightsixseven
Dec 16, 2024 01:50 PM
Falcon50
Aug 22, 2020 03:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Toolsin
Feb 2, 2016 06:55 AM
squirrels
Jan 3, 2001 09:19 PM
