.txt to .xdf ?????
Old Nov 23, 2006 | 09:01 PM
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
.txt to .xdf ?????
I am very new to this prom burning. I havent burnt one prom yet. I bought the harware from moates and downloaded TunerPro. I have read the stickies and understand most of it for not doing it before. I have just started and already hit a snag. I read my stock chip and saved the .bin ok. I have found a def file and saved that. When that saved it is a .txt file. So is what I thought I did was rename it to save it as a .xdf file. It did not work. What am I doing wrong?? No matter what I do to the file( rename or save a different way) when I select a xdf it always says invalid xdf file.
Old Nov 24, 2006 | 01:11 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Where did you download it from? Right-click on the link to the download and select "save as". Save it to your computer, then open it. If that doesn't work, either it's corrupt or invalid.
Old Nov 24, 2006 | 06:54 PM
muddyjimmy's Avatar
I must have been doanloading a bad file or something because I switched applications and everything is working fine. Thanks for the info
ZZ42Fast
Aug 30, 2015 02:39 PM
BMmonteSS
Oct 24, 2011 10:58 AM
Highpockets
Nov 5, 2010 11:23 PM
Nater36
Apr 8, 2010 11:21 AM
System1
Mar 2, 2009 10:58 AM
