93-95 TBI truck owners (or anyone using a 4L60-E), can you do me a favor?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Im going through the trans code in the PCM and Im needing to know some info on the range sensor.
The existing comments in the hack give the following for the values for each of the range bits:
Currently, Im trying to translate those raw inputs to how theyre stored as the actual selected gear range and Im getting something that makes sense, but its different from what has been given in the hacks. I want to make sure that what I have is actually right and I dont want to go off the info they give since alot of it is incorrect.
Can someone verify (either from a service manual or from a working vehicle) that the range inputs 1, 2, and 3 above actually correspond to the following gears in the table when that gear is selected? In the ALDL list, this is byte #25, I/O port C in the ADS file.
Code:
; PRNDL TABLE:
; RANGE1 RANGE2 RANGE3 GEAR
; 0 1 1 Low
; 1 1 1 Drive2
; 1 1 0 Drive3
; 1 0 0 Drive4
; 1 0 1 P/N
; 0 0 1 Reverse Can someone verify (either from a service manual or from a working vehicle) that the range inputs 1, 2, and 3 above actually correspond to the following gears in the table when that gear is selected? In the ALDL list, this is byte #25, I/O port C in the ADS file.
Code:
; PRNDL TABLE:
; 0 1 1 Low
; 1 1 1 Drive2
; 1 1 0 Drive3
; 1 0 0 Drive4
; 1 0 1 P/N
Car: 88 Camaro SC
Engine: SFI'd 350
Ok, cool...
The PCM looks up the state of the gear range from those bits, and I just wanted to make sure I had the right info before continuing on.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 88 Camaro SC
Engine: SFI'd 350
Not with my car. Id need a new crank if I wanted to use an automatic. My block had a misalignment issue that caused the trans not to be on center. Wiped out a nice 700-R4 that I rebuilt and the TC pilot wore a deep groove in my crank. Id still like to figure it out, though.
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
