Converting adress's
Old Dec 9, 2006 | 10:04 PM
escort_ford84's Avatar
Converting adress's
i have 2 simular ECU's here, but stuff is located in different adress locations like Accel Pump Vs. Coolant on ecu (a) = 40C, and ecu(b) = 332, is there a way i can convert allmy adress's using windows calcualtor?
Old Dec 9, 2006 | 10:19 PM
ok i took 40c and subtracted 332 and came up with DA, i think taking my hex adress and subtract DA from them is working
Old Dec 9, 2006 | 10:34 PM
my 7747 ecu fried and im having to use my 1228746 ecu and i dont have a very good 746 ecu file. some stuff converted out and works, but not much. anyone know where i can get a good 1228746 ecu or xdf file?
Old Dec 9, 2006 | 11:36 PM
ive been trying to dissasemble my bin but its not working out well.
Old Dec 10, 2006 | 07:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is both an ECU file and a commented hac of the '8746 code ($61). Check moates.net/fileman. If not there a web search should bring something up.
RBob.
Old Dec 10, 2006 | 10:24 AM
ok i found it, thanks.
Old Dec 11, 2006 | 01:37 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
332 (decimal) = 14C (hex). I assum you meant 14C and not 40C.
In any case, read this:
http://www.tunerpro.net/tutorials/UnderstandingHex.htm
Also note that some hacs have a base offset, usually something like $1000 or $4000, that should be subtracted when creating a definition.
Old Jan 25, 2007 | 01:43 PM
Perhaps "converting" was the wrong word here. i will explain this a little more. Looks like there are few differences but the 8746 and the 7747 ecu are very closely related. Most of the adresses on both are in the same order, just that the adresses are "offset" the amount i posted earlier. By adding the offset (DA) to the adresses on the 7747 ecu were working for the 8746 ecu. Now that i have the 8746 hac, i just use it now. Both numbers are (hex) so the 40c is correct. The '8746 hac from moates.net/fileman was right on the money accept for one thing and thats "Async Fuel Mult. vs. RPM" which i added myself.
Old Jan 25, 2007 | 02:25 PM
Great, now i cant get the hac anymore
Old Jan 25, 2007 | 02:39 PM
I had it on disk thank God.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
