Anyone knows here can I get a mapping of MAP volts to KPAs?
Old Dec 22, 2006 | 09:30 AM
HD4mula's Avatar
I'm reading/logging the MAP voltage with my LM-1 WBO2 unit. I would like to know if some mapping exist of the MAP voltage to the KPA values shown in Tunercat. This is for a TPI engine. TIA.
Old Dec 22, 2006 | 11:56 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Look in the help section of theDatamaster $8D.
Has a bunch of MAP info & cal numbers.
Old Dec 22, 2006 | 12:58 PM
HD4mula's Avatar
Could you please tell me where I can get that? I don't use that Datamaster. What is it? Sorry for my ignorance.
Old Dec 22, 2006 | 05:18 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If you made it this far, you have no excuse not to have a factory manual.
They are invaluable for troubleshooting and thourough explanations.
They even have a MAP to volts chart in them.
It has been posted here multiple times.
Do some searching and get a factory manual(or equivelant source)
later
Jeremy
Old Dec 22, 2006 | 07:43 PM
HD4mula's Avatar
Factory manual. Ok. I do have one but for a MPFI V6. Same thing less 2 cylinders. I'll look there then and see what can I find. I just thought this was so common here to be in a web page somewhere. Tks.
Old Dec 23, 2006 | 02:00 AM
3.8TransAM's Avatar
later
Jeremy
It is here, sometimes you have to break down and search. It helps.
It doesnt matter if it has 2-4-6-8-10 cylinders, the map to kpa is the same on the 6 and the 8.
RS Reaper
Oct 17, 2018 07:52 PM
