New be with tuning problems!
Old Jan 14, 2007 | 11:11 AM
sjaak84's Avatar
Car: 84 corvette 383ci
Engine: 383 crossfireinjection
Transmission: th700r4 coming soon 4l80e
Axle/Gears: stock 84 vette
Hello I am Sjaak from the netherlands. a very new be. Just start with tuning. I have a 84 crossfire vette. using the 7747 ecm with prominator and i begin with the starter bin. only chanche the BPW start the car,it idle ok but with cold engine put alittle trottle and engine almost die. running much to rich. when above 60 celcius run much better but a lot of back fire. then i change the AE vs TPS table [ i doublle it] when engine cold still **** but when warm up runs ok no backfire anymore. does the ecm when cold not reading the new BPW??? or do i forget something else,or do something wrong???? Hope somebody can help me[i don't know how to post my bin]
Thanks Sjaak
Old Jan 14, 2007 | 12:24 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
sounds like timing is off bpw is prolly fine but what mods have you done
Old Jan 14, 2007 | 01:23 PM
sjaak84's Avatar
It's a 383 with world s/r heads tpis headers 224/230@0.050 lift 0.479/0.480 lobe 114 cam 1.6 roller rockers sy-1 intake manifold 2.2 inch trottle body's tbi''s parralel. injectors 90' 85 feuel pomp. pressure 15 psi that's the set up
Sjaak,
Old Jan 14, 2007 | 02:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The BPW does not affect the AE. The AE is entirely pulse width based.
There is also a CTS based table to change the AE PW. May need to change that some.
RBob.
Old Jan 14, 2007 | 03:13 PM
sjaak84's Avatar
I can't find that table. i only see AEvsTPS and AEvsMAP or am i looking of the wrong place I use the $42.xdf is that right?
Old Jan 15, 2007 | 09:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I just checked a bunch of ECU files I have here, and none of them have the AE vs CTS table in them. It can be added to the XDF using TP's built in editor. Here is the table location and layout:
Code:
; FACTOR COOL 		Deg c
LD40C:	FCB 160		; COLD
	FCB 160		; -8.5
	FCB 144		; 6.0
	FCB 112		; 15.5
	FCB 96		; 23.5
	FCB 96		; 30.5
	FCB 80		; 37.0
	FCB 75		; 43.3
	FCB 64		; 49.3
	FCB 46		; 56.0
	FCB 36		; 63.0
	FCB 32		; 71.0
	FCB 28		; 80.0
	FCB 24		; 91.0
	FCB 24		; 107.0
	FCB 24		; 138.5
	FCB 24		; HOT
Also, double check the VE FL1 table layout. Many of the ECU/XDF files have the RPM & MAP axis reversed. No fun trying to tune as the wrong areas of the table will be changed. The TP window for the VE FL1 table should have 100 through 20 down the left side (MAP). Then 4 - 8 - 12 - 16 - 20 - 24 - 28 - 32 across the top (RPM x 100).
RBob.
Old Jan 15, 2007 | 11:18 AM
sjaak84's Avatar
@RBob I think it's to far in the dark room for me. I use TunerPro RT and find the Hex Editor but i don't know how to make changes in the .xdf I Read until my eyes are tired in the tuning stuff. to understand it. Is it possible that I e-mail my bin in txt to you so that you maybe can take a short look on it??
Street Lethal
Apr 30, 2019 12:14 PM
nuggie
Aug 25, 2015 01:27 PM
soarestransam
Aug 24, 2015 08:15 AM
ezobens
Aug 19, 2015 10:29 PM
zeitghaist
Aug 18, 2015 07:33 AM
