O2 swing points
Old Jun 8, 2015 | 07:57 PM
  #51
CORV3TT3's Avatar
Re: O2 swing points
Originally Posted by RBob
The feedback from the O2 sensor is used by the ECM to aim at the target AFR. The fueling will be changed (via INT/BLM) to move the PW to the targeted O2 switch point (the window).
The bottom line is that in closed loop operation the ECM is always targeting the O2 switch point(s).
That whole post has been VERY helpful. As has the stickies... and of course, RBob himself.
I've massaged my 02 switchpoint windows for idle to get me to within .2 above cAFR 14.7 and then a max of .5 below it (14.9 - 14.2). I've also lowered my proportional gains at idle too.
I think with the overlap on my cam, that helped tame the idle a lot. It's kinda rich, but the WB AFR is tracking closer to my desired cAFR.
MnRL - 637.98
Rich - 664.02
Lean - 598.92
I realize that's probably rather rich, but it's pretty solid at an idle now.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
