Speedo Calibration 730 VSS
Old Jan 29, 2007 | 12:44 PM
Jon614z28's Avatar
Car: 1992 Z28 Aniv. Edition
Engine: 5.3 L33 Turbo
Transmission: Tremec T56
Axle/Gears: 3.27 Borg 9Bolt
I need to know how to tune my 730 ecm for a rear end gear swap, i currently have 3.27, i used to have 3.08. I am using a t-5 wc tranny I have no idea where to start. Thanks
Old Jan 29, 2007 | 09:13 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
First, do some searching on this subject as it has come up MANY TIMES!
But, to give you the quick Reader's Digest version, you cannot recalibrate the ECM for a simple rear gear change - you must do that through the speedo gears in the tranny.
There are "switches" where you can make a LARGE calibration change but it's like 2:1 or higher. It's more from when a person swaps from a T-5 (or 4L60) to a T-56, which has a massive change in the pulses/second. But it is not "fine enough" to handle a simple rear-gear ratio change.
Again, do a search as there is a TON of info on this.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
