prom problem
Old Mar 6, 2007 | 03:02 PM
Keesey's Avatar
prom problem
i am new to this and trying to figure out what to do without spending tons of money.
i have a 88 305 tbi 5 speed camaro and a 87 305 tpi automatic trans am i want to put the 305 tpi in the camaro the problem is the prom right? where do i find them or how do i fix this issue without spending a million dollars and what other issues sm i going to run into.
Old Mar 7, 2007 | 07:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The most straight forward conversion would be to use the harness, MAF, and ECM from the TPI car. At a minimum will need to use a different ECM then the '88 TBI ECM. Either the '87 ECM with the MAF, or a '90-'92 ECM and convert to SD.
RBob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
