flash eeproms direct from laptop?
Old Mar 22, 2007 | 03:47 PM
boatderek's Avatar
i drive around fixing copiers-when i am employed. i use my laptop to flash eeproms in canon copiers to re-load software or update to newer version. it is a canon software that, i am sure, will only work for their applications. is anybody aware of something available that we can use to eliminate the programmer?
Old Mar 22, 2007 | 05:38 PM
Pelleplutt's Avatar
Car: Corvette -90 vert tripple black
Engine: L98 TPI
Transmission: ZF6
Axle/Gears: D44
Re: flash eeproms direct from laptop?
emulator ?
Pelle
Old Mar 23, 2007 | 10:04 AM
boatderek's Avatar
not emulator, just after converting ecm from eprom to eeprom.
Old Mar 23, 2007 | 12:02 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
The nvsram based emulator that I built for the '730 ECM sort of works like you describe. I use my laptop to upload new calibration data to the ECM over the ALDL port.
Old Mar 24, 2007 | 08:47 AM
Z69's Avatar
Z69
There are the Prominator and Ostrich also which replace the eprom.
Old Mar 24, 2007 | 11:04 AM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
I use an Ostrich(a real-time emulator)which plugs into the place where the chip used to be. The Ostrich in turn is connected to my laptop via a USB cable. I can change bins while the car is running. Tuning would consume a lot more time without the Ostrich.
Gene
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
lewandom
Oct 1, 2015 08:15 AM
efiguy
Sep 27, 2015 01:30 PM
