How do I datalog with tunerpro rt?
Old May 5, 2007 | 07:35 PM
Blazin4x4's Avatar
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
I got the pro prominator so I could tune in real time while it's running but I can't datalog with tunerpro rt. It wanted a file IIRC. What do I need to run tunerpro rt?
Old May 5, 2007 | 08:06 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: How do I datalog with tunerpro rt?
With TunerPro you need two definitions - the bin definition (XDF/ECU) and the ALDL definition (ADS). It sounds like you need to find the latter definition that matches your vehicle.
Old May 5, 2007 | 08:31 PM
Blazin4x4's Avatar
yeah ADS... thats it. Where can I an ADS for my 7747?
Thanks for the info
Old May 5, 2007 | 10:18 PM
Blazin4x4's Avatar
found it... thanks
Old May 7, 2007 | 01:23 AM
Blazin4x4's Avatar
I tried to datalog with tunerpro rt today and it said it couldn't create log file... What am I doing wrong?
Old May 7, 2007 | 05:08 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Before you log, select a file to log to.
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
tmellott89
Aug 16, 2015 02:58 PM
