about to burn baseline chip, combo questions!!
Old May 17, 2007 | 12:23 AM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys im about to burn my first chip for my newly tpi LO5 in my 84 anyways the heads are the 193 swirl ports with some minor porting and polishing (DIY) anyways will the stock 89 l98 program be ok timing and fuel wise with these heads i was thinking of making a chip with maybe 5 or so less degrees of timing across the table just to be safe
i tried searching but could really find much info on spark curves for the 193's as compared to 083's
thanks
steve
Old May 17, 2007 | 01:09 AM
91chevz71's Avatar
Re: about to burn baseline chip, combo questions!!
Here's a stock ARJU.bin spark curve from my old TBI 350 with those heads
Old May 17, 2007 | 07:30 AM
1984HO's Avatar
Car: 1984 Z28
that is a lot less timing but that main spark table is set up completly different any idea how i can make mine look similar mine has a larger rpm range as well as mine has the y axis as LV8 and the the x is rpm, that might be reversed but you get the idea
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
