Closed tps timing tabel.
Old May 29, 2007 | 06:37 AM
devilfish's Avatar
In the 8D code 730ecm. Where do I disabel it? I just whant use the main tabel.
And if I disabel it, will the timing corrections at idle still be in use If yes, where do I disabel that?
i use tunerpro with supe_8D ecm file
Cheers
Old Jun 3, 2007 | 04:17 AM
devilfish's Avatar
Re: Closed tps timing tabel.
ahh im sure there are guys outhere that have disabeld the "closed tps timing tabel" in the 8D code Care to tell me how?
Old Jun 3, 2007 | 10:32 AM
Section162's Avatar
Car: '90 Formula
Engine: L98 --> Ramjet
I think RBob has posted on how to do this. It's a "hardcode" change though, not something you can change with one of the common ECUs. I would try a search on his name.
EDIT: I think this is what you're looking for:
https://www.thirdgen.org/forums/diy-...ht=idle+timing
Old Jun 4, 2007 | 05:35 AM
devilfish's Avatar
Thank you whery much
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
