7749 with $58 runs fine after tune only 1 time
Old Jun 2, 2007 | 09:27 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I don't know if anyone has had this problem but I would like to find out a solution so I can do some good tuning. I am running a 355 with a tpis miniram 38# injectors, a 00384lm crower cam, dart heads and a vortec s/c @ 18lbs of boost.
Using C.A.T.S. and TunerPro RT, I lowered the base pulse constant ~vs~ desired egr (F28) from the .089 to .0622 to help drop the injector pulse width and help with the tuning. Then with the car running I started to adjust BLM on table F29C (Closed Throttle). Engine was running really good and INT's were staying right around 127 and BLM's were constant at 125 - 129. I had to end programming for the night and let the car cool off. The next day, I tried to start the car and it would barely run. It would start then stall and after 5 attempted starts when it gets warmed up it gets a little better but is never what I had it before. I can watch the BLM's go from 80 to 160 like a seesaw.
What table would be the recommended to adjust?
I am guessing tables from F50 to F57 but that is my guess. Any help would be appreciated.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
