Fried ECM
Old Jun 6, 2007 | 03:24 PM
summit56's Avatar
Car: 92 Caprice
Engine: L05 350 tbi
Fried ECM
I recently bought the autoprom and been tryin to play around w/ it. I can not figure this stuff out. i have been reading for months. anyways i loaded up tuner pro and tried to datalog and it wouldnt work. so then i tried to emulate and when i tried to save the bin file to the computer the ECM was smoking. the car is a 92 caprice. since i need a new ecm now can i just use a tbi truck ecm? the caprice ecm is hard to find and the defination files r rare/ which i cant get to work.
Old Jun 7, 2007 | 10:04 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Re: Fried ECM
On Nice.. www.tbichips.com you can get a ECM through them and get a Modified chip with it. I think your better off getting a Chip from this guy rather burning up another ECM.
Old Jun 7, 2007 | 10:39 PM
summit56's Avatar
Car: 92 Caprice
Engine: L05 350 tbi
Re: Fried ECM
I'm not gonna give up that easy. I went ahead and ordered a new ECM through the dealer. only 90 bucks but wont be here till tuesday.
Old Jun 8, 2007 | 09:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fried ECM
Make sure the cable from the autoprom to the ECM is plugged in correctly. If inserted backwards bad things can happen.
RBob.
Old Jun 12, 2007 | 03:41 PM
summit56's Avatar
Car: 92 Caprice
Engine: L05 350 tbi
Re: Fried ECM
Alright. I got my new ecm and it works. i figured out how to read and burn chips. I cant seem to data log though. i have 3 differnt datastream files for TunerPro and none of them work. TunerPro reconizes the autoprom connected in autoprom mode and for logging but when i click connected the dash does nothing. I tried using Winaldl and that failed also. I checked my aldl connection on the car w/ a old code/data reader and it works. Im running windows XP. Is there a file that i need for that operating system?
Old Jun 13, 2007 | 12:39 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Fried ECM
it sounds like the switches on the back of the AutoProm may be set wrong.
i have mine set to, the vertical switch in the middle postion, the horizontal switch toward the ALDL cable port.
more info is here,
http://www.moates.net/documentation....entation_id=14
Old Jun 13, 2007 | 10:20 PM
summit56's Avatar
Car: 92 Caprice
Engine: L05 350 tbi
Re: Fried ECM
I have already read that. I have the newer version of the Autoprom. I tried the inside switch in both directions with the outside switch out.
Old Jun 23, 2007 | 11:49 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Re: Fried ECM
With WinALDL, you can set the baud rate within WinALDL to 4800 and it should work.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
