165 to 730 swap - Won't Start
Old Jun 30, 2007 | 12:11 AM
88tpiolds's Avatar
Car: 88 Olds Cutlass GT, 92 GMC Sonoma
Engine: 86 305 TPI
Transmission: TH-700R4
Axle/Gears: 4.10 10 Bolt
I just swapped out my 165 ECM for the 730 ECM. I used the instructions linked from the tech articles page. My problem is, the engine won't start. I suspected VATS, so I've tried switching Bit 16 on and off but still no luck. I was watching my injector pulsewidth on TunerPro RT, and it stays at zero even while cranking. What may be keeping the injectors from firing? Could I have a fried injector driver or a faulty ECM? I'm using the AUJP bin with the injector flowrate modified for a 305 and magnetic VSS. Otherwise, it's a stock bin. I'm rather certain that I did my pinouts correctly, but if there is something obvious that I'm missing, or if you have any suggestions, your assistance would be greatly appreciated.
Keith
P.S. I tried searching the forums for this or a similar problem, but the search function does not seem to be working properly. It keeps saying that it found no matches, no matter what i put in the search box. I'm sure that I'm not the first person with this sort of problem.
Old Jun 30, 2007 | 08:12 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: 165 to 730 swap - Won't Start
Recheck your distributor wiring to be sure it is correct.
You should get the fuel pump relay when you first turn the key on and with a distributor reference pulse.
A noid light is worth the $5 for being sure the injectors are actually firing too.
TPS at idle setting about 0.45 or so, Distributor at 6*
Got a V8 memcal for the 730?
Old Jun 30, 2007 | 08:38 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Inj PW don't start displaying out the ALDL until the engine
is running above 400rpms, so that may be a red herring.
Get the few-$ injector noid like as suggested and verify
injectors are firing during cranking.
Do all the other sensors look ok while the ign is on, and
during cranking? Post the tunerpro scan file if you can.
(Byte 16 for VATs still has just a single bit {bit 4} to disable
the VATs, are you sure you unset it correctly? Can you post
your .bin file also?)
Old Jul 2, 2007 | 09:54 AM
88tpiolds's Avatar
Engine: 86 305 TPI
Thanks for all the input guys, but I have found the root of the problem...It turns out that the file I was uploading to my Prominator was not from the same location as the file I was editing in TunerPro. I guess that's what 1:00 AM does to you with no sleep since 5:30 the previous morning. I loaded the appropriate file yesterday, and it took right off. Everything else is working/reading like it should, and running great. Again, thanks for your help.
Keith
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
355tpipickup
Aug 19, 2015 10:02 PM
mizz0313
Aug 12, 2015 06:45 AM
