my first datalog, what do you think?
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
it's a bit long, but it's a 20 minute cruise down the highway, kept it pretty steady, between 60 and 70 on the highway and tried to keep the throttle as steady as possible. i'm having problems with overheating on the highway at anything over 60 mph, no matter what the weather. But lately, i've had an increase in power, and fuel economy and also the overheating has gotten better but still needs help. i attribute this to my 02 sensor, previously it was really acting weird, not steady at all, today when i plugged it in it at first it was a very steady oscillation but then it gets wacky about halfway through the log. in any case i'm not well versed enough to know what i'm looking at so i thought i would try posting it up and see what people thought. i was using tuner pro rt to log, and the file is in .adl format, csv was too big to post on the forum but enough people use tprt it shouldn't be a problem. just cut the .doc off the end of the file and it should read in tuner pro. thanks in advance! the car is a 1987 gta l98, 165 ecm with ABWT tune (which sucks!) its a 32b mask but for some reason i was able to datalog it with a 6E datastream,, dunno whats with that. thanks again.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Re: my first datalog, what do you think?
just wondering, thanks to the guys that have downloaded the file but is it coming up in tunerpro okay? i just changed then end to .doc but no one has commented on whether that worked or not. nevermind i just downloaded it myself, worked for me i can watch it.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
grr sorry fyi, i watch the file with a 6e ads, from mansur it's labled for 1989 years. now this brings me to another question, the car is an 87 but the ecm says its a remanufactured unit, how come i can watch it in 6e, thats the same ads i used to datalog, ABWT is 32b mask and i can watch it with a 6e .ads, are they the same?
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
soo, anyone notice anything in there?
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I'll leave it up to others to chime in about your log.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
thanks mark. punisher, you see anything wrong in there? i think i need to reset my IAC..
