Need a conversion formula
Old Aug 16, 2007 | 12:00 AM
Gearhead143's Avatar
I had a set of injectors flowed today and the spec sheet came back in milliliters. How do I convert this to lbs per hr? I have looked and I cant find a conversion.
Old Aug 16, 2007 | 07:15 AM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: Need a conversion formula
Well you would have to know the density of gasoline Id imagine. Then take the millileters times the density to get your mass in grams, multiply by gravity to get weight in newtons and convert to pounds. haha
Old Aug 16, 2007 | 09:44 AM
Ronny's Avatar
try onlineconversion.com
Old Aug 16, 2007 | 07:45 PM
HaulnA$$'s Avatar
1mL=1cc. To convert cc/min to lb/hr you divide by 10.5 or you can use this http://www.witchhunter.com/injectorcalc1.php4 . HTH
Old Aug 17, 2007 | 12:21 AM
Thanks HaulnA$$ The math worked great and the link confirmed it.
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
