VePHD Help! Almost got it!
Old Aug 22, 2007 | 02:11 PM
1raider's Avatar
I really like VePHD but can't quite get it to work. I have modded the vephddat.csv file to my TunerCat ecm's output.
The problem is that I run everthing fine, I get the output data and copy it over as stated to the VEPHDOUT (paste here) in the VEPHD VE Calculator.xls, I have the original bin in the Previous VE Table in the New VE Table Calculator (Tab) and from my understanding is that the new bin should now be updated but mine is not?
but i go to the new bin and i get nothing? I can email you a screen shot if you would like, I am sure that it is something simple I have attached a couple screen shots.
File Type: doc
Old Aug 23, 2007 | 12:45 PM
1raider's Avatar
Re: VePHD Help! Almost got it!
got it working with DM and TunerCat on a 16197427... I will see how close it gets to 128.
Old Aug 23, 2007 | 08:59 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Let us know how it works out
Old Aug 23, 2007 | 11:14 PM
HaulnA$$'s Avatar
I have been using a modified version of VePHD for the $0D mask for a few years now. You will find that it works well. It works best if you start off with a higher BLM correction factor at first, then use a smaller factor as the VE table starts to get roughed in. HTH
gsf-87IROC
Jun 28, 2011 08:33 AM
gsf-87IROC
Apr 9, 2011 04:53 PM
BIG 'G'
May 27, 2008 09:18 PM
jonarotz
Mar 27, 2003 12:54 PM
