Injector FLow Rate setting?
Old Aug 24, 2007 | 10:58 PM
im's Avatar
im
Hi guys just wanted to know what to set my injector flow rate to??..I have an 88 IROC 350 with stock injectors. I am using the ARAP bin with 6E.....single fire FI size is set at 22.36 lbs/hr..is this correct??...I checked my stock chip bin setting to compare the two and it was set to 23.04 lbs/hr....should I leave it at 22.36 or change it to 23.04??
Old Aug 25, 2007 | 12:20 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: Injector FLow Rate setting?
What size injectors do you have in it? Stock? I'd say stick with the setting in the chip you're using unless you've swapped the injectors, in which case set it to the flow rate for the injectors you're running at the PSI you're running.
Injector flow rate is a global setting for fuel flow throughout all ranges of the fuel/MAF tables. So, really, your datalog and/or WBO2 will tell you what to set it to. In a perfect world, though, you'd set it to what your injectors physically flow at your fuel PSI and use the tables to adjust your fuel trim in all points of your fuel/MAF tables.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tmellott89
Aug 16, 2015 02:58 PM
Firechicken86
Aug 12, 2015 10:07 PM
