TCC lockup speed
Old 08-29-2007, 12:36 AM
guy72's Avatar
TCC lockup speed
Since I switched from 32B to 6E (APYM) my tranny locks up at very low mph. I'm curious if I just can transfer the original values to the 6E bin. So my question is if the following values sounds ok to you? The 6E looks a bit different though compared to 6E.
Original bin:
TCC Unlock Speed (Low Gears) 39 MPH
TCC Lock Speed (Low Gears) 41 MPH
TCC Unlock,Speed (Higher Gears) 39 MPH
TCC Lock Speed (Higher Gears) 41 MPH
6E bin
Low Speed Limit For Low Gear Lock To Unlock Transition 20.00 MPH
Low Speed Limit For Low Gear Unlock To Lock Transition 21.00 MPH
High Speed Limit For Low Gear Lock To Unlock Transition 255.00 MPH
High Speed Limit For Low Gear Unlock To Lock Transition 255.00 MPH
Low Speed Limit For High Gear Lock To Unlock Transition 20.00 MPH
Low Speed Limit For High Gear Unlock To Lock Transition 21.00 MPH
High Speed Limit For High Gear Unlock To Lock Transition 255.00 MPH
High Speed Limit For High Gear Lock To Unlock Transition 255.00 MPH
Can I just replace the 20 and 21 values with 39 and 41 or what is your suggestion? Are these values normal?
Old 08-29-2007, 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TCC lockup speed
Yes, you can change the 20 & 21 to 39 & 41, that will work. Setting the TCC lockup points is much user preference. Which is also affected by the engine, convertor stall, and rear gears. One item to watch for is constant locking/unlocking of the TCC. That is hard on it. The other is leaving it unlocked for prolonged periods of time. That will run the tranny temperature up.
Otherwise set them up the way you like it to drive. Make a big difference.
RBob.
Old 08-29-2007, 11:15 AM
guy72's Avatar
Thanks! I will make the change to the former settings and modify from there. Just had to make sure I didn't break anything...
Old 08-31-2007, 04:25 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
No you wont really break anything, but i think it will be annoying to drive if the values are too high or too low. Lock up too soon and it will prolly be locking right as soon as its put itself into overdrive, then it will prolly chug down to some low RPMs. if its too high its like youll be waiting and waiting for it to lock while you have to take the RPMs to a relativly high speed just to cruise or lightly accelerate.
i like mine to lock at about 40 to 45 mph.
Old 08-31-2007, 04:53 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Originally Posted by RBob
... Setting the TCC lockup points is much user preference. Which is also affected by the engine, convertor stall, and rear gears. ...
As mentioned above (and with the few cautionary advisories) - this is one area you actually get to have a little fun and improve the way the car feels (with those few cautions mentioned).
And, it's even more fun if you ever get a chance to work on a newer PCM with full electronic tranny controls.
Old 08-31-2007, 08:19 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Usually the high gear (4th) lock/unlock speeds are higher than the lower gear speeds. That is strange that you had them the same, in both bins. If the speeds are far enough apart between low gear and high, you can actually go into 3rd gear, lock, goto 4th unlocked, then lock again! Of course this highly depends on the position of your right foot.
I am locking/unlocking at 40/38 in 4th, and 32/30 in low gears.
Old 01-06-2021, 04:42 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
I know this is an old thread, but I thought I would ask the question here so maybe others would be helped. The tune I'm using has both the "low gear" and "not low gear" TCC lock/unlock speeds at 38 (lock) 36 (unlock). This seems to be the "stock" settings for AUJP. It is creating some mildly concerning operation since installation of the "Corvette" servo. That is, under light throttle, the transmission seems to be shifting from 3rd with converter locked, then unlocked, then 4th, then locked again. Can anyone recommend better lock/unlock speeds to establish a smoother transition from 3rd to 4th under light throttle? Anything other than light throttle seems to be fine, I guess because the tune isn't allowing the converter to lock in 3rd before shifting to 4th.
Old 01-07-2021, 11:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It might be due to the coast release logic:
Code:
; COAST RELEASE, TPS SW POINT, (32 MPH)
; LO MPH COAST LOAD LIMIT, 3.1% TPS
; HI MPH COAST LOAD LIMIT, 3.9% TPS
This where under light load (see the TPS%) the TCC is unlocked when below those values. Not sure how the 'vette servo could affect this, as it is only used for the 2nd gear band apply/release.
RBob.
Old 01-07-2021, 03:53 PM
rt66er's Avatar
Engine: L31 350 TPI
Okay, full disclosure. I forgot that I also did a small adjustment to the governor at the same time I did the servo swap; this achieved the shifting behavior I was shooting for, but it also seems to have made the light throttle 3-4 shift a little hinky. I would be interested to know at what speeds others have their TCC lock/unlock set.
MikeT 88IROC350
11-08-2014 09:13 PM
jjcuff1
03-18-2014 04:33 PM
Jeep_Joint
10-17-2012 09:00 AM
GWW
05-18-2008 06:06 PM
guy72
08-21-2007 12:51 AM
Quick Reply: TCC lockup speed
