EEPROM 27SF512 Chips from here?
Old Aug 31, 2007 | 06:42 PM
Steve40th's Avatar
I read these are the right chips? I have a 93 LT1, and just want to make sure these are the multi programmable super wammy dammy chips I need so I can have spares to burn while datalogging. Top of page? Are these right?
http://www.mouser.com/search/refine.aspx?Ntt=27SF512
Old Sep 3, 2007 | 04:41 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: EEPROM 27SF512 Chips from here?
Those are the ones that I use. I'm guess-in you want 28 pin.
They must be erased each time before you burn a new bin.
Old Sep 3, 2007 | 05:21 PM
Steve40th's Avatar
I have the Moates Burn1, Moates adapter so I can put this on. I just want to make sure its compatible as there are all kinds of hardware out there.
Old Sep 3, 2007 | 06:39 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Hi Steve, those are the ones. I ordered from the same company about a week ago thru my work. small world ..They are the exact same ones Moates sends you with there kit...
Old Sep 3, 2007 | 10:05 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
'93's use the same 256k chips the 90-92's do, so with those 512k chips you will need to load your bin into the upper half of the chip. Just in case you didnt know.
Old Sep 14, 2007 | 11:38 PM
Steve40th's Avatar
Got it, thanks. I think the Burn1 does it automatically. Will check though.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
