Changing BLMs with injector constant?
Old Sep 3, 2007 | 05:24 PM
Steve40th's Avatar
My constant is 29.1 for a FORD SVO 30# in my 93. My BLMS are hanging around 108. If I raise the constant, to say 30.1, will it lean it out that much?
Old Sep 3, 2007 | 09:57 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Changing BLMs with injector constant?
That is the wrong thing to do.
Fix the problem right by adjusting the VE tables.
Old Sep 3, 2007 | 09:59 PM
Chewy72ss's Avatar
I'd have to agree that the VE tables would be the best way to fix your problem.
Old Sep 4, 2007 | 12:40 AM
Steve40th's Avatar
Okay, I agree with you guys. So what percentage on the VE's do I need to go to raise the BLMs to 128?
My thing with the injector constant was that it was lower than the constant is supposed to be (by formula only) and by raising the constant I figured it would raise the BLMs as it will lean the mixture out as the BLMs are 108 everywhere in the rpms.
Old Sep 4, 2007 | 07:05 AM
Chewy72ss's Avatar
I'm not sure what ECM you are using, but if at all possible, try and do some datatracing in the VE table. Wherever the BLMs are low, cut the VE values by (108/128) about 15%.
Let anyone correct me if I am wrong, because I am fairly new to this myself.
Old Sep 4, 2007 | 11:20 AM
Steve40th's Avatar
According to the TTS Datamaster it is pretty low , BLM numbers, everywhere. If I could upload the file, you all can look at them'DA2 files, 1993 Corvette LT1 auto.
Otherwise I can email, since they are BIN's(program) and UNI for TTS
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
