ADS Super Chip....
Old Sep 7, 2007 | 10:24 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
ADS Super Chip....
I know , I know......... aftermarket chips are anything but super...... but I was wondering if an aftermarket chip like the one I bought 10/12 yrs ago (ADS SuperChip) could be erased and re-programmed?
I will have to start programming soon I guess and want to know if I can work with what I got already.......
Old Sep 8, 2007 | 12:39 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: ADS Super Chip....
That is probably the best thing I can say about the ADS Superchip.
I started with the ADS Superchip "piggyback" for my 91 GTA back in the 1990s and used it when I got into eprom burning. I just pulled out the original eprom and inserted a flash prom instead.
On my ADS Superchip, the eprom was not soldered in (and I heard others for different model years are either). So I gently pulled it out (but inserting a flat screwdriver and working both ends) and then I was able to insert a flash prom in place.
Unfortunately, the AT29C256 flash proms are no longer made (they were a great replacement). But you can insert a zero force adapter and then just swap out eproms.
Alternatively, you can see how Moates adapter can be utiled with your memcal. I don't use the Moates adapter, but you should check it out and see if it helps out.
Good luck and welcome to tuning. Also, you use the $6E MAF system, which is probably the best defined MAF system used on 3rd Gens. While I personally use SD - the $6E is one of my favorite MAF systems to work with.
Old Sep 8, 2007 | 12:47 AM
Camaero's Avatar
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
Just to comment on the Moates adapter, I have to say it works like a beauty and is very very simple. I really like that thing.
Also, he now has the C2 SST 27SF512 Chip which, according to moates.net, "Works fine as a drop-in replacement for the AT29C256."
So there you go.
Old Sep 8, 2007 | 01:29 AM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Blank chips are pretty cheap, i bought two but really only ever used one, just a backup.
I think most people would agree that youd be better off pretending that the ADS chip doesnt exist haha.
So if you dont have a stock chip to start with, all you need after you have burning equipment, is to get a blank chip, download the stock tune (a .bin file), and burn that file to that blank chip. youll be able to tune form there, where i dont believe that youd be able to tune the aftermarket chip..
hope that made sense, im quite tired..haha
Ed1LE
Sep 30, 2018 09:14 AM
no green
Jan 9, 2016 09:22 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
