Feeding wideband output to ECM
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I've got an AEM UEGO wideband setup. It has an analog output and one of the modes is a simulated nernst cell narrowband 0-1v output. Can I connect this to the stock purple o2 wire of my '165 ECM, or is this not how it is meant to be used.
Thanks,
Matt
Thanks,
Matt
Car: 89 Formula 350
Engine: 409 nitrous' small block
Re: Feeding wideband output to ECM
Yep, that's exactly how it's meant to be used. Hook it in directly where your stock o2 sensor fed in.
TMZIrocZ350
Oct 7, 2015 12:09 PM
efiguy
Sep 27, 2015 01:30 PM
