more issues in tunerpro RT with data log
Old Oct 16, 2007 | 11:39 AM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
hello again...
im using tunerpro RT and attempting to data log, but.. when i push the button to connect the aldl, i get an error that says "serial port error" could not initialize port...
im using the USB ALDL cable from moats, is this what is causing the issue? do i need to set up TP to see the usb? and how?
thanks
Old Oct 16, 2007 | 06:19 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: more issues in tunerpro RT with data log
Have you set up the proper port in TP RT?
Tools>Prefernces>ALDL/Emulation
Click on Test for valid ALDL cable using settings.
If you get a not found or functional error, try another port until you do.
You can also go
Control Panel>System>Hardware>Device Manager
To see what ports and thier corresponding numbers are to change settings in TPRT.
I believe you also have to install the FTDI drivers for the cable. I already had these drivers installed on my computer for my Ostrich before getting my Moates ALDL cable, so I can't verify if this step is needed for the ALDL cable.
Old Oct 16, 2007 | 11:16 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
And make sure no other applications have your interface's serial port locked up (e.g. trying more than one logging application at the same time won't work).
Old Oct 17, 2007 | 01:22 AM
Axle/Gears: 4.10
well, following those steps, i found the cable, but now i just get a message that states failure to connect... any ideas
Old Oct 17, 2007 | 11:58 AM
You did apply the new settings in TPRT ALDL set-up, correct?
Old Oct 17, 2007 | 02:22 PM
Mangus's Avatar
Transmission: T5WC
And you're using the proper definition? If using it with your '88, is the 10K resistor in place? It needs to be.
Old Oct 17, 2007 | 03:05 PM
Axle/Gears: 4.10
yup its in the 88, i have it switched to 10, not on open.. i did the set up as told, but one thing that may be wrog is the select log file for rec/play what is supposed to be selected there? if it helps, i can emulate fine.
Old Oct 18, 2007 | 09:48 PM
What version of TP RT are you using?
Help>About Listed in the upper right corner as Build 4.14.0xxx.xx
Old Oct 19, 2007 | 06:24 AM
Axle/Gears: 4.10
build 4.14.0030.00
Old Oct 19, 2007 | 07:38 PM
Mangus's Avatar
Transmission: T5WC
Originally Posted by avengersteve
build 4.14.0030.00
Although I'm not sure it'll help, download the latest version and re-check for your cable in preferences.
Old Oct 19, 2007 | 10:12 PM
Mark, this is my experiance with the lastest build, vs the 0030. http://tunerpro.net/forum/viewtopic.php?t=796
Old Oct 20, 2007 | 12:16 AM
Mangus's Avatar
Transmission: T5WC
Originally Posted by Six_Shooter
I just got a new (to me) laptop, so I have re-installed all the programs I need for tuning as well as a few others.
Anyway, I thought it would be nice to have th enewets version of Tuner Pro RT (v 4.14.0365), so I downloaded it and installed it.
I decided I would verify my cables, to make sure my Serial port works on this laptop, I have bought another one recently that the serial port didn't function.
I plugged in my home made max232 based ALDL cable, went to tools>prefernces>ALDL/Emulation and clicked on the test for valid cable. no go. So I tried com2, no go. Hmm.
I then tried my USB ALDL cable, a Moates.com ALDL Extreme, tried a couple com ports, then decided to check my device manager, to expedite the task, and saw com 6. So I tried that in TP RT, and nothing, even tried a couple other ports, still nothing.
I figured I would try the version that came on my Moates disc, 4.14.0030.00, BAM! Sees both cables (tried them at different times, unplugged one before plugging in the other).
So I figured I would use the check for updates function of TP RT, thinking that maybe going through the program would change something. Lost connection to the ALDL cables, both of them. Removed the new version again, which for some reason did not show in my start menu, so I removed it via add/remove programs in my Control Panel, and re-installed the older version, and again I am back to seeing both cables.
Is there anything that I may have missed? I wouldn't think that there would need to be any extra seetings to change for the new release, that and I don't see any settings that may need to be set, that don't need to be in the older version.
Does anybody have any copies of the releases between the two I have? .0030 and .0365. I wouldn't mind trying a newer version to try and find where this possible bug started.
What does "see" mean? The cable test? It could very well be broken. However, that's unrelated to the problem in this thread.
EDIT: I've just fixed the ALDL cable test. Re-download TunerPro from the site in about 5 minutes and you'll get the fix. NOTE: this does not solve the problem Steve is seeing (1227165 monitoring/logging works fine for me).
Old Oct 20, 2007 | 12:28 AM
Yeah, see = validate both cables as found and functional.
I was sent the next release after 0030 (0323), at least that's what I am told, so I am going to install it and see where I get.
It may be unrelated or it may be related, as datalogging or ALDL connection seems to be an issue for a lot of people.
Old Oct 20, 2007 | 12:30 AM
Mangus's Avatar
Transmission: T5WC
Re-download TunerPro. I just fixed it for you.
Old Oct 20, 2007 | 01:10 AM
Thanks Mark, that worked.
Old Oct 20, 2007 | 12:46 PM
LCLegendLT1's Avatar
Hey Guys Im new to this forum, but it's got some great info.
Im having a similar problem. I can start TunerPro RT, and check for the serial cable, and it finds it. Then I try to connect to the car and it won't. After I try to connect I can go back into preferences and check for it again and it wont find it.
I have no clue where to go from here Ive tried everything I know.
Old Oct 20, 2007 | 01:10 PM
Mine was doing that as well. Unfortunatly I never did figure out the specific problem, the laptop I had that problem with was not mine, and would have to give it back eventually anyway, so I decided it was time for me to buy another one of my own. The old PII IBM laptop with Win98SE wasn't quite enough to do what I needed, and the serial port didn't function either. It's going to be strictly a back up Laptop.
My problem also started AFTER I had already connected and datalogged a few times over a few weeks, then just randomly stopped connecting.
Old Jun 12, 2008 | 03:01 PM
???'s Avatar
any chance you ever figured it out?
Old Jun 12, 2008 | 03:36 PM
???'s Avatar
double post.
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Accerrito22
Sep 5, 2015 09:34 PM
