$32b cylinder select hex
Old Oct 16, 2007 | 09:31 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Can anyone with tunercat tell me what the hex value for 6 cylinders is in $32b? I have tunerpro.
Old Oct 17, 2007 | 07:09 AM
randy4762's Avatar
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Re: $32b cylinder select hex
Hi,
I copied this directly from the xdf file "Number of Cylinders $00=8 $C0=6 $80=4" Is is what you want to know? It is in address "09" BTW. In case it is not listed in your program you could just modify the definition to include it.
Randy
Old Oct 17, 2007 | 07:27 PM
bl85c's Avatar
Car: '85 maro
Are you sure that's $32b?
Old Oct 19, 2007 | 10:25 PM
randy4762's Avatar
I know I used a modified 32b that I found on moates to copy the description from. It should be the same on the the others. Here is a screenshot from the tunerpro xdf. FWIW I just converted my car to 6E and it is alot better already, 4 hours tuning and all I have left is WOT stuff. Idles perfect....
Randy
Attached Thumbnails b cylinder select hex-32b.jpg   b cylinder select hex-32b2.jpg
Old Oct 20, 2007 | 12:47 AM
bl85c's Avatar
Car: '85 maro
I just figured out what my problem was. Output type was set as floating point instead of hex. Duh! Thanks for the help anyway.
Old Oct 20, 2007 | 04:17 PM
randy4762's Avatar
Your welcome.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
