oops easy question adapter chip
Old Oct 25, 2007 | 06:39 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i unplugged my i guess its the memcal? from the back of my moates adapter chip and theres a million little holes in the back of the im gonna keep calling it the memcal lol
i have no idea which direction to plug this big brown socket back into the adapter chip
Old Oct 25, 2007 | 06:45 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Re: oops easy question adapter chip
all hail the search button
found this image
plugged the memcal back in with it facing that way and the pins over as far as they can go to that side
Old Oct 25, 2007 | 06:51 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
That would be the correct way to insert it.
Old Oct 25, 2007 | 08:01 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
id like to chime in on this topic, you do that so that you can carry over the limp home mode program correct? so would car run with out the stock chip pluged in?
Old Oct 25, 2007 | 11:06 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
yes, you do it for limp home.
but its in case there is a problem with the chip you burned
Old Oct 26, 2007 | 11:24 AM
The knock sensor filter is also contained on the MEMCAL. So there is also the purpose of keeping that intact as well.
Old Oct 26, 2007 | 07:56 PM
DENN_SHAH's Avatar
Six is right, i knew i forgot something.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Keith5
Aug 27, 2015 04:37 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
