Prominator/injector issues???????????
Old Nov 1, 2007 | 06:38 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
guys I need alittle info, I'm running all the mods in my sig plus a ZZ4 cam and Brodix IK 200 heads. My issue is that only the injectors on one side of the car are firing. Any Ideas???? EMC/Prominator issue?? Wiring harness??? I'm running a slightly mod ARAP bin... I have a ton of bins on my computer... I forgot whats the STOCK BIN for an 89 L98 AUTO... Just want to flash in the stock bin to see what happens... thanks again!!!!!!!!!!!!!!!!
Old Nov 1, 2007 | 07:44 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Prominator/injector issues???????????
Injectors on 1 side only would be a fuse or the ground wire came off the pin at the ECM.
Probably a fuse if there is not power on both sides of the injectors (on the side of the harness not firing)
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
