Max RPM stock module??
Sorry not sure if this is the right place to post this but Im wondering if someone can tell me roughly what the stock ignition module on a TBI 350 can run for RPM before crapping out. Im thinking that this may be my problem. I have richend and leaned out to no avail, and it seems to cut out at the same RPM all the time. Right around 5000rpm. Just wondering if someone can relate to this or if I should replace it with something from the aftermarket?? Thanks for any help. Its on a slightly modded 350 heads/cam/intake etc with a Msd coil and wires. Thanks again.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: Max RPM stock module??
I have ran the stock GM dist. and coil to 5500rpm multiple times in my old TBI engines.
Plugs are at .45 I figure that should be fine but you never know!! Im just thinking it may be time for a new module, not sure. Trying to narrow down the problem. THanks though
Car: 89 Formula 350
Engine: 409 nitrous' small block
Is it the actual original module or a cheapo parts store unit? I've run the stockers upwards of 6 grand without a problem. I also havent' had much problem if I buy one of the better parts store brands. Luck with the cheaper aftermarket brands had been erratic at best.
Car: check
Engine: check
Transmission: check
I've taken engines to over 7K RPM with a GM small cap distributor. JY unit from a Caprice, including the coil.
RBob.
RBob.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
When a coil and module run out of steam depends on the amount of cyls and rpm.
On a V8, the stock GM HEI coil and module run out of juice at 4800-5000 RPM. Every test ever done on them have shown this to be true. My stock coil and module also dies of at around that RPM.
It comes down to the inductance, turns ratio, and resistance of the stock coil and the resistance of the module driver. RPM and cyls determine the amount of charge time. At 5000 RPM on a V8, there is almost 24ms/8 = 3ms to charge the coil between spark firings. That is how long it takes to charge the stock coil using the stock module. On a V6, this comes out to be around 6800 RPM. RBob was probably referring to a V6.
Overall, to reliably light the air/fuel on a V8 with an HEI above 5000 RPM then you need a better coil to start with. If you need more than that then get a better module later on.
Engine: 3xx ci tubo
Stock HEI coil and module on a V8 at 6500 RPM? If it did rev without misfiring then the VE was so low that the plugs would fire easily. This means little HP was being made and the engine was out of it's range of usable HP.
Ok thanks for that again guy's but Im running an MSD Blaster TBI coil with the correct connections. I gues that maybe I should try a new module. Im not sure if it is the O.E one or if it is aftermarket but I will look into it.
Car: 2000 BMW M5
woops I spoke too soon. Stock module, accel super coil (remote). This is a MAF Holley stealth rammed 327 w/ big cam and aftermarket heads. Not a slug stock TBI/TPI 4500 rpm tug motor. Peak HP with this setup is north of 6200 rpms.
Engine: 3xx ci tubo
6500 RPM, 327ci, stock module with super coil sounds right. A stock coil wouldn't do it.
Engine: 3xx ci tubo
What do you mean by cut-out? Does it fall on it's face or just stop pulling? When I had spark blow out it was like the fuel shut off and nosed over until the RPM dropped. Stock TBI heads run out of wind at around 5000 rpm? What kind of cam do you have in it?
Its a dynoed 300hp engine even with the basic mods that I have plus I do my own tuning. Its not a firebreather by any means but it gets up pretty good in my 4000lbs P.U. What do you think??
Engine: 3xx ci tubo
If you have a WBO2 then you might see the misfires if they are truly happening (not enough ignition). I am not good at guessing, but if I had that setup I would guess it is the cam first (street cam), then the heads. Can you hear it misfire?
Yes you can hear it miss. The funny thing is that this engine in a similar truck with a carb ran and pulled fine to 5500rpm no problem. Of course it was running out of power there but would just like to beable to shift at about 5300 or so when needed.
Car: 1983 G20 Chevy
Transmission: 4L60
Stock AC Delco GM Coil, Stock AC Delco Replacement GM module, Stock style cap and rotor. Made 379 RWHP @ 6,400 rpm
"Stock AC Delco GM Coil, Stock AC Delco Replacement GM module, Stock style cap and rotor. Made 379 RWHP @ 6,400 rpm"
Fellas, as usual thanks for all this useful info, I had the same questions about my stock TBI ignition system.
Fast355, what year ignition and type ignition are you talking about there, the one with separate coil or coil on the distributor?
Thanks,
Paul T.
Thanks,
Paul T.
Engine: 3xx ci tubo
Must have been an external HEI coil.
What kind of VE, CR, timing, etc was it setup for?
I have revved a stock V8 HEI coil and module to 7K RPM before also. The thing is that to build an engine to make power reliably at 7K+ requires decent parts. In doing so it will also be setup for high rpm power so the logical path is to put the proper ignition on it to take advantage of all the expensive high RPM parts.
EDIT: info here: cyberdave.org/HEICoilInfo.html. The title Coil Saturation Time and data below has the most useful information for the original poster.
Car: 1983 G20 Chevy
Transmission: 4L60
Thanks,
Paul T.
Thanks,
Paul T.
The other site is my personal page(s).
Re the module information, the description was written years ago and the prose
isn't very good. The equations are correct however, AFAIK.
The highlight is that spark energy is proportional to the SQUARE of the module
CURRENT. Aftermarket coils don't make any more energy than is already there
from the stock module. They only gain saturation time by reducing spark
energy.
BTW, a joule is one amp-volt-second. I neglected to mention that in the write up.
Have fun.
