tunerPro-Prominator
Old Nov 15, 2007 | 08:36 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
tunerPro-Prominator
hey guys, I just installed 24lb Ford injectors in my car and was looking to change the contants with TunerProRT. I and using a modded ARAP bin. I'm kinda new to the DIY Prom stuff so I just wanted to double check with you guys. I see in the costants "Single fire FI size@40psig" and "double fire FI size@40psig" both are set at 22.36 in the ARAP bin. is this where I would change my settings and if so I'm thinking i'd be looking to set them both around 24,correct??? Thanks in advance.. all moddes to my car in sig if it helps
Old Nov 15, 2007 | 08:57 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Re: tunerPro-Prominator
What is the part number on the injectors??? It would be nice to know what pressure they flow 24lb before you change the constant. 24lb@36psi equals 26.3lb@43.5psi. Grab the part number off the injector and google it to find the specs. As for the setting, yes your need to change both values.
Old Nov 15, 2007 | 09:14 PM
Car: 89 Formula 350
ok, part# from Summit FMS-M-9593-A302
24lbs/hr.
flow rate(cc/min) 255.0cc/min
I'm going to change fuel injector values from 22.36 to 24.0 if that seems correct???
Old Nov 15, 2007 | 09:56 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Yeah those are rated 24lb/hr at 39.15 psi....start at 25 and tweak as needed as long as you are running stock fuel pressure
24lb@39.15 psi is equal to 25.29 @43.5 psi.
Old Nov 15, 2007 | 11:13 PM
Car: 89 Formula 350
thanks for the help..... last i checked my AFPR was set at 49
Old Nov 15, 2007 | 11:22 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
No need for AFPR anymore Sell it to recoupe some software bills....
Old Nov 15, 2007 | 11:25 PM
Car: 89 Formula 350
I'm confussed on this one? will the AFPR have no effect now? I dont want to pull it off. Should I have it set on a base setting? does the software totally over ride? sorry for the questions
Old Nov 16, 2007 | 07:48 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
AFPR is a tool used to adjust fuel pressure right???? You will adjust fuel pressure to get an injector to dispense a certian amount of fuel per pulse. Increasing fuel pressure will increase the volume output of the injector. Decreasing the fuel pressure will decrease volume output.
You now have the ability to change the injector constant as well as the pulse width, ect. with tunerpro and your prominator. There is no need to fiddle with fuel pressure to try to get an injector to react differently in regards to fuel delivery. Set the pressure and leave it alone. Adjusting the pressure is a global cange that affects all fueling tables in the ecm. By trying to tune for part throttle, idle and WOT you would be wasting huge time if you were also changing the fuel pressure at random times throughout the process.
By the way you are going to like your prominator. I had one a few years ago and thought it was a hoot compared to erasing chips. Can you store 4 bins on it at once or has that increased as well??? I used to love having a nitrous tune, a regular tune, a highway tune and one for when the car had to goto a shop so that it could not be revved over 3K.
Old Nov 17, 2007 | 12:04 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
watcha do to make the car not run over 3000 rpm? set the fuel to zero for those VE values?
Old Nov 17, 2007 | 12:24 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Its been a few years but I THINK it allowed you to pull out all the fuel/spark at a certain rpm in the form of a rev limiter. You could also limit speed as well via a speed limiter.
Old Nov 17, 2007 | 01:24 PM
Car: 89 Formula 350
you can also set the fuel cut off to 3000RPMs
