injector constant question
Old Nov 19, 2007 | 07:12 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
this might be a stupid question but i was wondering if you are supposed to set Fuel Injector Constant to the fuel pressure of the injector u are running? for example I saw the stock fuel injector constant in my ARAP bin was 22.36 and I had 22lb stock injectors. Now I'm running Ford 24lb injectors I set the constant to 24 is that correct? Seems to be running well.
Old Nov 19, 2007 | 09:37 PM
Car: 89 Formula 350
Re: injector constant question
bump
Old Nov 20, 2007 | 12:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its not the fuel pressure but the injector size is what you set the constant value to. You have it right but called it the wrong thing. For 22lbs injectors, set it to 22, and for 24lbs injectors, set it to 24. However, if you increase the fuel pressure above the stock 42 PSI, then you will probably need to raise the constant a little bit to compensate. 24lbs injectors at 42 PSI might act like 24lbs injectors, but at 48 PSI they might act like 25 or 26lbs injectors. Make sense?
Old Nov 20, 2007 | 04:31 PM
Car: 89 Formula 350
yeah, thanks!
jklein337
Sep 19, 2018 06:23 PM
bamaboy0323
Sep 3, 2015 06:07 AM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
